graphics difference between project and family
jledgewood409
jledgewood409
i created our new logo for our title block using a fill pattern. i made this logo a generic family and inserted it into the title block family. when i print either from the title block family or the project the title block is in the curve in the logo seems segmented. when i print the logo from the logo family file it appears okay. i am including PDF's of both conditions.
jledgewood409
i forgot to mention it is for revit 2017
D_Slaa
We have our logo as a .png in the title block family. That might be easier if you have a good quality image?
Ilic.Andrej
Create the filled region with the <Invisible Lines> border. It will be still segmented but less annoying.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
jledgewood409
we had an image as a logo. we couldn't get the resolution high enough. we would create a PDF of a sheet and the logo would not print crisp. once we inserted the logo it would always come in at 72dpi.
Sahay_R
I'm with @Ilic.Andrej on this.
Rina Sahay
Revit Architecture Certified Professional
Create the logo with the solid hatch in AutoCAD.  Import it in generic annotation family, do not explode, and load it your titleblock.
