Grading Cut/Fill calculations only work when one Toposurface is present in the model
jagostinho74
jagostinho74
Founding that when using the Graded Region tool the Cut/Fill calculations are only performed if a single toposurface element is present in the model as per the video below.
Is this happening to you as well?
Model file with toposurfaces also available.
Assistant BIM/CAD Manager
Manchester, UK
alan_eu
Not only having toposurfaces, but also having them duplicated with graded region made with different phases...
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
