Global Parameters Question
AidanHawkins
Message 1 of 10
AidanHawkins
I am working on an office building
Each room I have created is an office
I have text parameters in identity data that show the names of different occupants in each room.
I have created parameters named occupant 1, occupant 2, occupant 3...
Is there a way I can count how many people are in the building using a global parametre, that recognises each time I fill in an occupant it will give me a total count of the people in the building
Regards
Aidan
Replies (9)
Message 2 of 10
hmunsell
i would use a Shared Parameter and then use the Has a Value filter. Then you can Calculate Totals. in this example i used the Type Mark, but you should be able to use it on any parameter.
Howard Munsell
Message 3 of 10
Edit:
if you want to only count the rooms with Occupant value, then use a Filter: [your parameter name]  [is greater than] [blank].  See example below:
You can count the number of occupants but not by Global Parameters.  Create a Room schedule, add a number or an integer parameter to the schedule, for mat it to calculate totals, enter the value for each room and you will get the total occupants.  You can also create a calculated value parameter to get the occupant = rom area / occupant load factor.
But you definitely do not need a Global parameter here.
Message 4 of 10
Not with a Text Parameter.
Message 5 of 10
AidanHawkins
okay so I will just create another project parametre and enter the total number of occupants in each room manually and then caluculate totals to get the total amount in each building?
Message 6 of 10
That'll work.
Message 7 of 10
Yes you can but you can also carry on with your original approach.  See my edited post.
Message 8 of 10
AidanHawkins
Morning Guys
Here is the example from my project
Please look at Level 2
How can I total the amount of occupants using the count parameter?
Message 9 of 10
Did you read my post?
Message 10 of 10
AidanHawkins
Yes but I have 2 occupant parameters
How do I add the counts together? is it possible? do I need a formula?
Aidan
