Hi All,
I'm having a problem with the glazing system, that I set the glazing system to existing phase, but some of the glazing panels are still in current phase. I tried again by selecting the whole glazing system then change to existing, but still didn't work. Has anyone have the same problem before and how to fix it? Thanks a lot,
Select the curtain wall, use Cut to Clipboard and then with the correct phase active, use paste aligned > Same Place or Current View. That should reset the overall curtain wall and its sub-elements.
Steve Stafford
