Glazed Sloped Roof
6 REPLIES 6
zs-17
461 Views, 6 Replies
Glazed Sloped Roof
Hi
I created a sloped roof with an opening and a roof inside I changed its type to sloped glazing within the same slope value. The problem I have that I can't add grids and mullions not from the type and nor by adding it manually. How to manage this problem, please?
Regards
6 REPLIES 6
constantin.stroescu
in reply to: zs-17
Use Edit Footprint instead of Opening>Shaft and then you'll be abele to create the second roof
Constantin Stroescu
zs-17
in reply to: constantin.stroescu
I still have a problem The cut will vertical when I need it as by face. The frame will be inside the roof. Another problem is that the frame is segmented and not as an arc to follow roof lines. Is there a way to fix it?
in reply to: zs-17
3D Beams will follow the curves.
zs-17
in reply to: barthbradley
I don't know how to do it
syman2000
in reply to: zs-17
If you want to make the mullion curve, you have create arc segment. Use the break tool to break the arc into many parts.
When you apply mullion, it will follow segment and create much smoother curve.
zs-17
in reply to: syman2000
Yes, it solves the segmented mullion. I still looking for the opening
