Glass in Elevation View
Message 1 of 9
Hi guys and girls,
I'm currently completing a set of plans for a client and have finally decided to ask about an issue that I have been having for quite some time now. I have an insitu shower family with a glass shower screen and I cant for the life of me get the screen to appear as transparent in the internal elevation view so I can see the tapware beyond.
The shower screen is an extrusion in the shower family and I have assigned glass as the material. I have also transferred project standards from project to family and vice versa to make sure that everything is on the same page. I've also changed the extrusion from a solid to a void but when I do this it eliminates the screen from plan view.
My current work around is to change the extrusion to not be visible from the front/back and left/right and then use model lines to be just visible in front/back and left/right. This appears fine but I use revit so I don't 'fudge' stuff with linework and I lose sleep over things like this.
Replies (8)
Message 2 of 9
What category is it?
Message 3 of 9
I've tried it as plumbing fixture, casework as well as generic model. I've also tried to insert the screen as a nested family.
Message 4 of 9
Is the elevation view the same Phase the shower was created in?
Message 5 of 9
Yes everything in the entire job is created in new construction. The phase filter is "show all".
Message 6 of 9
I have a theory. Want to hear it?
Message 7 of 9
Go on
Message 8 of 9
Corsten.Au
Just suggesting a work around till someone gives you the real solution you looking for...
I would try to keep those glass in a selection and give a transparency in filter..
Following example of wall and tub behind.. that wall can be a " shower cubicle " family ..
and tapware in your case..
1. Filter 2. Graphics option transparency.1. Filter 2. Graphics option transparency.
Corsten
Building Designer
Message 9 of 9
Create the glass panel as nested family so that you can TAB-select or filter-select it and override graphics to transparent.
Or instead of using a 2D elevation view, use a 3D elevation view.
