Generic Model - Visible in elevation/section when all Display Options are OFF
m_moyaZL6YZ
m_moyaZL6YZ
Hi forum,
I set the visibility of a generic model family just to be visible in 3D views. But when I load the family in the model and ROTATE it....appears in elevation / section (this does not occur when placing the element parallel to the elevation/section)
Has anyone experienced this in the past?
RSomppi
Share the family to avoid guesses.
arq_42
@m_moyaZL6YZ  wrote:
... to be visible in 3D views. But when I ...ROTATE it....appears in elevation / section (this does not occur when placing the element parallel to the elevation/section)
You're answering your own question. When you rotate the element and it doesn't match the family's orthohedral views, Revit considers it to be in 3D.
Anyway, as @RSomppi  says, share the family if you can, so we can give you more details on the issue.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
m_moyaZL6YZ
Thanks for the prompt response both. I did not know that by rotating the element Revit would consider it to be in 3D.
Family is attached but I believe that with your answer is all clear.
Regards.
