Generic Model adaptive
sak9537
Message 1 of 18
sak9537
i am making a lotus petal for one of my projects, i tried to follow allow the steps from YouTube but for some reason i am not able to make a void though the solid mass. it shows orange when I
make a void
Replies (17)
Message 2 of 18
Make the surface larger so that its edges don't touch the inside border of the void and the void's ref points.
By the way, I think could make the leaf on its own without the void.  Share the family here.
Message 3 of 18
sak9537
this is the family. thank you
Message 4 of 18
make a void
Post link to the You Tube Video too.
Message 5 of 18
sak9537
Message 6 of 18
see attached
Message 7 of 18
sak9537
Thank you so much. But may I know what my mistake was?
Message 8 of 18
I just deleted yours and re-did it.  I'm not sure what was wrong with yours.  Didn't spend any time trying to figure it out either.
Message 9 of 18
sak9537
I just wanted to change the scale. I can't do it if I don't know how to make it that's the reason i asked you. but i guess i will just use your file. Thank you it is really helpful. saves me time.
Message 10 of 18
Here is one without a void (2024).
Have you tried what I said to fix yours?
Message 11 of 18
Are you saying that you are not able to delete it and recreate it yourself? If you are able to, like I was, then that's the solution.  Sometimes "stuff" happens.
Message 12 of 18
sak9537
tried it but dint work. maybe i am not doing it right. But I will try doing it again. Thank you.
Message 13 of 18
What do you mean by "I just wanted to change the scale"?
Message 14 of 18
sak9537
changing the size of it or the angle.
Message 15 of 18
You mean flexing it via changing the Parameters?  Yah, I agree with @ToanDN. It doesn't flex to well with the Void approach.  I would follow @ToanDN suggestion if you're intending to deviate much from this shape.
Message 16 of 18
Funny. Even the guy in the video is resolving issues with the void towards the end.
Message 17 of 18
Here is how I have fixed it exactly the way I described:
1. Make the surface larger.
2. Cut geometry:
Message 18 of 18
sak9537
thank you. I tried it and it works!!
