Generic Light on the wall facing wall
Is there a flip command or anything of that sort in revit? I am working on a project and I have put a linear lighting fixture on the wall . It is sitting on a reference plane  but it's distribution is facing the wall. I tried to rotate the work plane but the luminaire is not rotating. Could you guys please advise?
Thanks & Kind Regards,
Prattusha.
PijPiwo
In your light fixture family, you can add a flip arrow.
Thank you for your reply. But my question is can I flip it on the go so that I don't have to go back to the Create tab and then change. Also I tried to change from the create tab, it is not working.
That's exactly what the flip arrow is for, flip the fixture on the go.
PijPiwo
Add a flip arrow(s) in the family, load it to your project, select it and click on the flip arrow.
