Gate Valve Family Help
Hopefully none of you are to annoyed with me as I keep trying to solve this issue, so lets do this one family at a time,
Gate Valve,
in classes 600, 900, and 1500
If you open the attached file, and go through the sizes,
being 2 inch and so on,
You see as you go up in size the family seems to mess up in a way,
I believe that I have the dimensions as needed following the other attached file, using page 21 for this family,
but if someone could maybe help me fix the merging parts or anything I messed up in general, that would be greatly appreciated,
Thank you ahead of time for any comments.
This contains the other file, page 21 for Gate Valves.
Okay I feel I am getting closer but still having some issues,
For the Gate Valves, I don't see the stem changing at all so things are looking not to scale in a way, even if I didn't have it locked or had no formula.
As for the Globe Valves, which I will attach them in reply to this, just something all together is wrong with them.
Any help would be grateful,
this isn't just for me, its for a lot of people,
Thank you so much.
Matt__W
You need some parameters to adjust the stem handle length as the sizes change. If you look in a 3D view and go from 2" to 12" you'll see everything changes except for the handle length. It just gets swallowed up by the body of the valve. Add a few reference planes and constrain your parameters to those (never constrain to the geometry) and enter the correct handle lengths for each size. Should be a "simple" (I.E. easy but time-consuming) task to fix the valves.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Thank you, I will give that a shot.
