GABLE ROOF PLACEMENT
Mohamed_Arshad
Advisor Advisor
Mohamed_Arshad
Hii Genius,
I have a Autocad file i need to make model according to that drawing walls and floor are created easily, But gamble rook and roof shed is in issue.
i attached the file please make an solution as soon as possible.
it that drawing please ensure at which level i need to draw gable roof to match drawing.
how to make shed like drawing which is attached to the gable roof.
Mohamed Arshad K
Software Developer (CAD & BIM)
Cut a hole in the main roof and draw a second roof with the walls separately.  At what level should this be placed?  Roof level is a good one, although you can draw it on any level.
2 Roofs.  Gable sketch shown below, and Shed could be done with a single sketch line using Roof by Extrusion.
Mohamed_Arshad
ya that's ok at any level we can draw roof, But i need to match the drawing so i'm asking at which dimension level is better to march roof like drawing shown .
Mohamed Arshad K
Any level.  I would create levels for Ground (0.00), First(2.75) and Attic (5.46).  The logical place to draw the roof is on the top level.
constantin.stroescu
something close to what TimELZ49 suggests...
https://knowledge.autodesk.com/community/screencast/73dda05c-6c82-4567-a259-cd06b211b8ec
Constantin Stroescu
Mohamed_Arshad
THANK YOU VERY MUCH SIR!!!
THAT'S WORKS
Mohamed Arshad K
