I have tried a "Filled Region" and a "Masking Region" at this place where this 2'-10" space where the door will go.
I have tried bringing it forward in all the options and have even tried sending it back in all the options.
The wall I am working is is a "Stacked wall" (wood frame over CMU) and this is what shows when using "Foundation" level. Which is fine, just that I cant seem to manipulate it the way I want.
Converting individual lines to invisible did not seem to work either.
Any thoughts?
Thanks!
Gelöst! Gehe zur Lösung
Can you confirm what you're trying to do? Are you trying to block out a piece of wall to show where a door will go?
Check if your view is set to Wireframe.
