I am using the exact same Foundation various walls. The Dimension is 800mm wide. When creating a foundation plan though, some are coming out as 805mm and others 800mm. Dimensions are set to use project units, and project units are set with one decimal point ie 1234.5
Note saved revit 2021
Link copied
