formula for a yes/no parameter depending on length an an other yes/no parameter
I'm trying to make a formula for a yes/no parameter which is depending on other yes/no parameters AND a dimension value.
I have an dimension parameter: railing_diepte
a 1st yes/no parameter: b_aantal_spillen_diepte
a 2nd yes/no parameter: b_baluster zichtbaar_diepte midden
Basically what I want for the 2nd yes/no parameter is:
1. to be turned OFF when the 1st yes/no parameter is ON
2. to be turned ON when the 1st yes/no parameter is OFF
3. to be turned OFF when the dimension parameter is less then a particular value (in this case: <200mm)
how can I put this in a formula?? I've added a screenshot to show you guys how far I got with this.
I've searched this forum and others, but no result. Thanks a lot to the guy/girl who can help me!!
Keith_Wilkinson
Sorry, don't have time to look at this in detail but this should get you fairly close I think.
The ControllingInteger takes care of the various combinations via a nested if statement - so condition of your first yes/no parameter and the length of the wall.
The second Yes/No parameter is then controlled by an if statement based on that integer value - so if it's '1' then the answer is False 1>2 which will set the parameter to No and if it's '0' the answer is True 2>1 which will set the parameter to Yes.
Let me know if this helps or if you get stuck.
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Thanks! you're sollution almost worked,I changed a few things on the integer parameter so the family acted the way that I wanted:
Although I still have to figure out what the formula behind the integer and the ParamB parameter means.. Do you want to explain that one to me please?
Really appreciate your help!
Keith_Wilkinson
One of the best resources for formulas is here :
http://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
I've just used a selection of bits to give you what you are after.  But in essence the Integer Parameter first checks the condition of ParamA, if this is checked it returns 1 if it's unchecked it returns 0.  Then it checks the wall length, in my case if it's greater than 500mm it returns 1 and if it's less it returns 0, for any other condition it returns 0.
You now have a parameter which is either 1 or 0 nothing else.  So now we use this to drive ParamB - If the value of the integer is 1 we want it to be unchecked or 'False' so we use 1>2 (as 1 is less than 2 this statement is false) for any other condition (which can only be zero) we want the box to be checked or 'True so we use 1<2 or 2>1 (both these conditions are true so either would work).
If you wanted you could make it a lot more complex but there is not need in this example thankfully as nested 'If' statements can get quite complicated!
Maimonides
Thanks!
I always wondered how a checkbox (yes/no parameter) is reflected in a formula. I never could just write 'false' or 'true', but 1>2 and 1<2 does the trick so it seems.. That's pretty weird!!
Thanks! you made my day
Keith_Wilkinson
You're welcome - happy to help.
I agree, it's always felt like an oversight on the part of ADesk that True / False aren't included - there may be a good reason for it though but at least there is a workaround which is pretty easy.
Maimonides
