- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to make a formula for a yes/no parameter which is depending on other yes/no parameters AND a dimension value.
I have an dimension parameter: railing_diepte
a 1st yes/no parameter: b_aantal_spillen_diepte
a 2nd yes/no parameter: b_baluster zichtbaar_diepte midden
Basically what I want for the 2nd yes/no parameter is:
1. to be turned OFF when the 1st yes/no parameter is ON
2. to be turned ON when the 1st yes/no parameter is OFF
3. to be turned OFF when the dimension parameter is less then a particular value (in this case: <200mm)
how can I put this in a formula?? I've added a screenshot to show you guys how far I got with this.
I've searched this forum and others, but no result. Thanks a lot to the guy/girl who can help me!!
