Forcing the Preferred Language in the Deployment or during Installation
- Mute
- Permalink
- Report
Prior to the web deployment method, we were able to force the preferred language via a switch in the installation string (/language en-us for example). With the web deployment method, the batch files does not include a language switch. Per the documentation on this page, the deployment language is set based on the regional settings of the machine creating the deployment (behavior confirmed; in my case it was set to en-US):
When installing from the deployment, I cannot seem to find a way to force the preferred language. I would like Revit shortcuts to be set to "ENU", regardless of regional settings. I believe this was the behavior of the previous deployment method when using the /language switch, which forced the shortcut setting during installation:
@danny.polkinhorn might have the answer...is it no longer possible to force this during installation? I discovered the behavior change because our custom Revit.ini files that we copy to the UserDataCache folders (used to seed the user Revit.ini file) have all paths specified under [DirectoriesENU] and since the preferred language has changed (for example some machines are now set to ENG), they complain about template paths.
I did a bit more searching and found this page, which does reference the switch "-l <option>", but it states that this is to change the language shown in the installer. It does appear we can no longer force the language, but I'm not 100% sure so any help on this would be greatly appreciated! Thanks.
Firmwide Design Technology Manager - HOK
@dourevit
