Force elevation view
MiWolff
Mentor Mentor
MiWolff
Components should have a force elevation view for situations in which sections only appear to be parallel to the object in question. If Revit decides a view is 3D rather than an elevation you may get stuck with the model view and not the 2d drafted symbol reserved for elevations.
Alfredo_Medina
Can you give an example, can you post an image?
