Folders are not showing properly
I have a precision dell 7720 as shown below
Radeon Pro and AMD FirePro Software Version - 18.Q1 drivers .
Pro Software Enterprise Edition Windows Version - Windows 10 (64 bit)
System Memory - 16 GB
CPU Type - Intel(R) Xeon(R) CPU E3-1505M v6 @ 3.00GHz
Display resolution 3840x2160
When I open a folder from Revit, folders are stacked above each other, and some icon are too small.
Any help plz
zhukoven
@Anonymous, which version of Revit do you use? This issue has been addressed in Revit 2017.2 update, while previous versions will remain glitchy.
I have both Revit 2017.2.3 and Revit 2018.1 installed on Windows 10 Pro & 3840*2160 screen resolution with 250% scaling, and everything looks fine.
It is 2017.0.1. Any advice how to update the software!
zhukoven
@Anonymous, you should be able to download an update through the Autodesk account if you have an active subscription, or using the Autodesk Desktop App. Otherwise check out this link: revit news
