Floors below view range visible in view
I'm working on a model with many levels close to each other (not a building) and my plan views are showing floors below that are not within the view range.  I no not want to see these floors that are outside of the view range.  Any advice is appreciated.
Karol_Piroska
yap, that's the way Revit works. If "floors" are too close (1.2m or 4ft) both will be shown. I would love to know the logic behind this myself. Pretty much a nightmare if you work on industrial structures.
You can only manually hide it, filter them based on some parameters or worksets.
Wow, that is absurd... Thanks for the response.
Alan.johnson1970
Check your Underlay setting, and make sure its set to NONE
AJ.
It is set to none
Alan.johnson1970
Good answer,
I didnt know that. - I do now thanks
AJ.
adrian_jTTKH5
You can use foundation slabs instead. They won't have this behavior.
