When creating a floor or roof by modifying its sub elements, the thickness of the slab isn't uniform, as seen here:
Also Revit gives a warning: "Thickness of this Floor may be slightly inaccurate due to extreme Shape Editing."
Is it possible to achieve uniform slab thickness with basic floors/roofs using modify sub elements? Or do I have to use model in place, or mass hosted slabs, which isn't preferable?
What about just making the floor thicker (e.g. 2 layers w/base Variable)? Top layer would be the "keeper", so to speak.
