Floor/wall join removes wall in elevation
Good morning,
at our office we've just started using Revit for architectural purposes.
This week i ran into a problem.
I joined a compound wall to a compound floor. If i look in a section this looks okay, but you can see the floor line at the outside of the wall. In elevation view this results in a cut wall. (see attached pictures/project)
I have tried to make 2 floors already, but then i cannot join the inner walls properly to the floors.
Can somebody help me with this problem?
thank you!
ennujozlagam
you can try this and see if helps. thanks
thanks for your response. I forgot to mention that we us Revit LT, so i don't think i can create parts?
