floor to wall join
floor to wall join
Message 1 of 39
floor to wall join
hello,
i've made a floor with structure assembly layers and i try to join it to the building's Ext wall.
there is a window that disables the connection (the window is sill height 0, if i change it to something else the wall-floor join becomes ok, but i need it to be set to 0).
what can i do to make the wall and floor join as the blue marks indicate?
i've tried attaching wall's bottom to floor and also join geometry, but nothing seems to work.
Replies (38)
Message 2 of 39
What if you change the wall base height to lower than 0?
Message 3 of 39
nope, it didn't work.
Message 4 of 39
Are you saying the you want to drop the base of the wall to meet the core layer of the floor?
Message 5 of 39
Corsten.Au
In Wall Edit, Structure, in Section, you can unlock a year and extend it  to suit the construction.. do you thing this will help you in this situation?In Wall Edit, Structure, in Section, you can unlock a year and extend it to suit the construction.. do you thing this will help you in this situation?
Corsten
Building Designer
Message 6 of 39
You can split the floor at the window area and model a separate floor without the finish layer underneath the window.  Then join the floors and attach the wall base to the main floor (see pic).  With that said, model a structural floor and a finish floor separately maybe a better option after wall.
Message 7 of 39
well that could work, but it's not the solution im looking after.
i have a big and complicated building and it will be lot of work to split every floor perimeter for the walls ( i have many windows which are the same as the one i showed).
Message 8 of 39
exactly
Message 9 of 39
If you have a lot of this condition then I would suggest model the structure and the topping as two separate floors. The structural floor goes to the outside of the wall and the topping stops on the inside. Attach the wall go the structural floor and join geometry the two floors.
Message 10 of 39
Corsten.Au
Easier way would be to add that missing piece in Window family itself..
may be parametric ..with size and material parameter..
Corsten
Building Designer
Message 11 of 39
@Anonymous wrote:
exactly
Well then -- drop your level on which you build the floor -- and/or -- raise the floor core to be flush with the level.  That's how it's done.  Ain't more difficult than that.
Message 12 of 39
ennujozlagam
@Corsten.Au what the **** are you talking about????? they are discussing on how to join floor and wall. Smiley Sad
Message 13 of 39
Corsten.Au
Just let me know one thing.. are you facing problem in joining Floor and External wall only
in the situation where there is a WINDOW??
Corsten
Building Designer
Message 14 of 39
ennujozlagam
my apology my bad. thanks
Message 15 of 39
yes, exactly.
Message 16 of 39
You know; sometimes I think both you and @Corsten.Au are crazy -- until I realize you're right.
Live and learn. Smiley Wink
Message 17 of 39
someone?
Message 18 of 39
@Anonymous wrote:
someone?
Maybe offset the bottom of the Cut Opening in the window family a tiny bit up.
Message 19 of 39
@Anonymous wrote:
someone?
It seems to me that the issue you are having is brought about by that window you have placed at floor level. If you can't model it, then it stands to reason you can't build it.  The rough-in for the window obviously needs to be higher than the floor, whether or not it's Platform Framed or Balloon Framed. So raise the window. That's the solution.  Simple.  The wall and floor are joining correctly for platform framed construction.
FWIW...
Message 20 of 39
