Floor Plan Visibility
Message 1 of 9
My model does not show up on "Floor Plans: Level 2" or on any of my ceiling plans. How to resolve?
Replies (8)
Message 2 of 9
Sahay_R
1) Select a wall and look at its Base Constraint under Properties - you will see that the base constraint is NOT Level 2. Change it to Level 2.
OR
2) On the Ribbon - click on View>>Plan Views>>Floor Plan. You will get options for levels to create plans from. Select Level Plate - which is the level currently associated with the objects. When the Level Plate plan is created, delete the original Level 2 plan from the Project Browser, and then rename the new plan that you have created to level 2 (or whatever it needs to be)
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
chrisplyler
Still, his Level 2 plan view has a cut plane at 4', and that DOES cut some of his wall regardless of which Level they are hosted on, so why does his Level 2 plan not display them?
Message 4 of 9
Sahay_R
But they do show up on the Level Plate plan.
OK - I did delete the Level 2 plan and re-create it. No other changes. I get a lot more than was in the original file from the OP.
@chrisplyler - there are times when ours is not to reason why.....
Rina Sahay
Message 5 of 9
chrisplyler
It's because of the Phase and Phase Filter parameter settings of that view.
@Sahay_R I've got to reason why all the time.
Message 6 of 9
Sahay_R
@chrisplyler you mean you have the reason why all the time!
Rina Sahay
Message 7 of 9
chrisplyler
Same with the Ceiling Plans. They aren't on an appropriate phase.
Message 8 of 9
Adjusting the Phase Filter solved the problem. Thanks.
Message 9 of 9
chrisplyler
Glad to help. Consider pressing the Solution button on an appropriate post in the thread.
