Floor plan, tiled floor: how?
10 REPLIES 10
Message 1 of 11
Joris.vd.Meulen
29524 Views, 10 Replies
Joris.vd.Meulen
I got a room which needs some floortiles. I would like to show those on my floorplan.
How I did it: annotate > region > filled region. Selected a model pattern.
However: I need to outline the whole thing. which is rather timeconsuming....
My question: isn't it possible to create a tiled floor on 'floorlevel' and other components are 'above' the tiles and therefore tiles aren't shown...
3Pinter
love python coding
3Pinter
love python coding
10 REPLIES 10
Message 2 of 11
in reply to: Joris.vd.Meulen
Don't use a Filled Region.
Instead, Create a new "finish floor" which will sit on top of your "structural floor".
Create the new Floor using skeych lines, the finish the sketch.
Then go to the Properties of your new finish floor and offset its height about 1/8" above the Level of your Main Floor.
Then, edit the structure of your "finish floor" and assign it a Tile Material, with a Surface Pattern using a Model Pattern
to show the tile lines. Give the tile a proper thickness, like 1/4" or whatever thickness your tile will be.
Objects above the floor will display properly, as they are "covering up" the floor in your Plan View.
If you are in a workset enabled project, place your "finish floors" on a separate workset.
Use this same principal for making tiled walls.
Hope this helps.
Hope this helps.
Message 3 of 11
How do you get the tiled floor? is it built in? I can't find floor types in RevitCity.
Message 4 of 11
L.Maas
L.Maas
Floors are system families.This means they are not loadable. You can copy/modify floors in the project and you can copy floors between projects. But you do not have a loadable floor family.
Just like walls (also a system family) you can modify the structure, the materials etc
If I need a tiled I use a tiled material as top layer.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
Message 5 of 11
in reply to: L.Maas
How do you get the tiled material though?
Message 6 of 11
L.Maas
L.Maas
Something like this:
Floor Structiure with tile material on top
Floor Material. Settings for 2D Views
Settings for 3D
Louis
Settings for 3D
Louis
Message 7 of 11
in reply to: L.Maas
the terrible dsaster with my revit is taht the floor tile is not on the material editor
Message 8 of 11
L.Maas
L.Maas
Than you create a new material and make settings as you would like them to represent your tiles.
The screenshots in previous postd already give a good idea how it can be created.
Louis
Louis
Message 9 of 11
in reply to: L.Maas
STill doesnt work. I  have tried to make teh new material and applied the hatch pattern. Unfortunately I dont have the 'relief pattern'. This is where the autodesk over sphisticattion can be often painful.
Message 10 of 11
in reply to: L.Maas
I have done exactly as per your screen shots and I am still not getting teh result. I don't have teh relief pattern option
Message 11 of 11
L.Maas
L.Maas
Which options you have available is dependent on the material you start with. For example you can copy the "Porcelain, Ivory" to your project/template.
Then you can rename it and modify the settings.
Louis
Louis
