Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
floor pattern shows up in some plumbing fixtures
raysanziaei
raysanziaei
hi guys,
not sure why floor pattern shows up in my urinals!
A few possibilities:
- They are overridden to be transparent in view
- The family use linework for plan presentation.  Edit the family and add a masking region, or set the 3D element (if it exists) to be visible for plan/rcp.
raysanziaei
Thank you for responding.
The problem was graphic display option was on wireframe and some of the families had this box unchecked:
Thank you
syman2000
Is your urinal drawn as lines instead of 3d model? If it is drawn in lines, you may need to add masking region to hide the pattern.
Thank you
Thought I has suggested to check that...
