Floor not visible in floor plan but only visible in 3D
Message 1 of 27
Dear all,
I modeled the floor in revit 2015 and divided it into parts for floor finishes purpose. It went well and all floor finishes are visible in 3D view but the same floor is not visible in floor plan.
I clicked the bulb button and selected "select by face" and its still there but there is no option to unhide it. secondly floor category is now Analytical Floors (1).
any solution how can i make it visible in floor plan?
Replies (26)
Message 21 of 27
Lance.Coffey
Autodesk Support
Autodesk Support
For those seeing this thread in the future, since my last post (2021), there has been a troubleshooting guide released to help with this situation: Guide: Troubleshooting missing or hidden elements in Revit
If the guide isn't leading to a solution, and you don't find an answer among the existing forum threads, I would suggest posting a new thread to discuss the behavior.
Lance Coffey
Technical Support Specialist
Message 22 of 27
jdwangsvick
Observer
Observer
Just figured it out for me, same problem.
VIEW
-Visibility/Graphics
--Floors (click the row)
--- [Notice to the right, "patterns" may have two buttons showing as "Hidden".]
----Click one of them, click the visible check boxes.
-----Click ok.
------Be happy!
Im trying to upload pictures too, may or may not work.
Message 23 of 27
wnisbett1
Thank You - Much appreciated
Message 24 of 27
wnisbett1
This is the one - Thank You
Message 25 of 27
mary.schmitz-dex
Hi,  This time for me it was the view range, sort off.  It was set looking down and I needed looking up.
Message 26 of 27
mary.schmitz-dex
Hi, Thank you for the reply. But this time for me it was the view range, sort off. It was set looking down and I needed looking up.
Message 27 of 27
archer_habliR4MWP
Community Visitor
Community Visitor
you may have the parts material set as the original , you'll need to change that in the model and than go to the plan , hit on a blank space. now, in the property panel , under graphic visibility change to shows on parts and that should solve it
