Floor not visible in flipped section
vojtech.zufnicek
vojtech.zufnicek
Hello.
I have a created floor (creation phase: Current state, Demolition phase: None), within the construction phase I will demolish a part of it (through the "antimatter" created in the given phase). It is displayed correctly in the floor plan, in some sections as well. But in some cuts, the floor is not visible. I tried different phase settings, filters, hidden objects, nothing helped. When I tried to copy another section (in which it is displayed) and then rotate it. It was displayed when it was not rotated, but not anymore when it was rotated by 90°. And in a 180° turn, yes again. And when I reverse the incision, it disappears again.
Even if I recreate the section, it still shows/does not show the floor according to the flipping of the section.
So, the setup of that section is the same, it's just reversed - and one time it shows the floor, the other time it doesn't. Don't know what to do with it?
I suspect the View Phase Filter - maybe the Graphic Override Settings of the specific override that the Phase Filter is using.  Could be hierarchal thing.  In other words, you have other overrides in place that are taking precedence in the View.
Element Visibility Override Hierarchy | Revit 2019 | Autodesk Knowledge Network
Define the Graphic Display for Phase Statuses | Revit 2020 | Autodesk Knowledge Network
Here are other things to check when you can't find stuff in the View:
Can't see it in the view? Here's 33 reasons maybe why - Revit Forum
vojtech.zufnicek
I thought so, but no 😞
The section does not show that floor, And when i flip the section, it appears. And when i flip it again, it disappears again. The section is through that floor.
So the whole settings for visibility of elements remains the same, only the floor shows up according to orientation of the section. That´s strange to me.
Let's look at the RVT and see.  Post the file here.
vojtech.zufnicek
Ok, i had to clean the file up
On floor plan is only one section - B3-2.  if you flip it, the floor disappears.
dont know it is some strange setting - but visibility of that section remains the same, or some bug in model / Revit?
