Floor Materials Keep Merging
chiomaun94
chiomaun94
Hi, hoping I can resolve an issue I keep having. Every time I try to create multiple floor materials, the previous floor materials will change to the newest one I've added as if they're somehow linked. The boundary lines are completely separated and so I can't seem to figure out why it's happening.
rxi.gg
Can you upload an screenshot?
you create different materials and aplied them to the layers of the floor?
Be careful duplicating materials, you have to duplicate visualization too. If not, the visualization will change to both materials, the original and the copy.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
When you duplicate a material, go to Appearance tab and duplicate or replace the Appearance asset.
