You mean "floor material"?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Do you mean that you have an existing material that you want to transfer between projects? Manage Tab=>Transfer Project Standards.
...or do you actually mean a mat; a piece of protective material placed on a floor?
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new member ![]()
Please see screencast below for some simple steps to insert a floor in Revit and edit the floor types based on your requirement.
I hope that helps, and do let us know if you have additional questions.
Looking forward to hearing from you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
