Floor issue
Floor issue
Luke.Gawthorp
Message 1 of 9
Floor issue
Luke.Gawthorp
Does anyone ever have this issue.
I have created floors but not they are just coming up as a double cross hatch for some reason...
They was showing fine previously, I don't know if this is due to level change?
Any assistance is appreciated.
Replies (8)
Message 2 of 9
Simon_Weel
Seems to me like a cut pattern in the applied material.
Message 3 of 9
Luke.Gawthorp
Update,
This seems to happen when i set the gravel at 300mm if i do it at 100mm it shows... the max depth i can do of the gravel (cross hatch) is 180mm.
Message 4 of 9
Simon_Weel
Sorry - I fail to see the problem?
Message 5 of 9
Luke.Gawthorp
when i make the gravel thickness 300mm it then hatched the whole floor (image on original post) if reduced to 180mm it then appears as show in second image.
I believe it maybe to do with the slope... How would i fix this.
Message 6 of 9
hmunsell
what is the structure of your Floor?
Howard Munsell
Message 7 of 9
Luke.Gawthorp
see below
Message 8 of 9
Try moving Rome layers out of Core.
Message 9 of 9
hmunsell
i don't have your materials :-), but i duplicated your structure and do not have the same issue.
I'm in inches vs MM, but that shouldn't matter 😉
Would you be able to upload your model? or a basic model with just these floors in them showing the issue.
Howard Munsell
