floor height tag in reflected ceiling plan (2015)
jledgewood409
Message 1 of 9
jledgewood409
I would like to know if there is or can be a floor tag created that resembles a ceiling tag that measures the height of the bottom of the floor in the reflected ceiling plan?
example; we have exposed bottom floor structure and would like to tag the height of it similar to tagging the adjacent ceiling in another room
Replies (8)
Message 2 of 9
dzanta
you can use the Spot Elevation command in the Annotate Tab, Dimension panel of the Ribbon.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 9
jledgewood409
is there a way to change the appearance of the spot elevation tag so it looks like the ceiling tag
Message 4 of 9
dzanta
yes.  select the tag that was created, open the family itself, modify it and load it back into the project...update your existing tags.
Message 5 of 9
jledgewood409
from what I gather there is no way to edit the spot elevation tag family. it seems to be a systems family?
Message 6 of 9
cbcarch
In the Browser, scroll down to Families, Annotation Symbols, Spot Elevation-Target. Highlight it, right-click and select Edit.
I would do a Save-As, then load into project.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 7 of 9
dzanta
create spot elevation tag
select it
go to edit type in properties
duplicate
change symbol to use
remember to create a custom symbol first (annotation family) and load it into your project so you can select it in the edit type window
Message 8 of 9
jledgewood409
getting closer. our ceiling tag is the text (label) with opaque background and its boxed. is there a way to get that look
Message 9 of 9
dzanta
most text/labels have a feature within the instance properties to "show box" and change the background from transparent to opaque.
if not, create a masking region, colored and ordered
