Floor Elevation mark
Message 1 of 10
Hi, sometimes when I fix the elevation through elevation mark, It jumps to somewhere else. Thanks for help
Replies (9)
Message 2 of 10
Not quite understanding.  What jumps to where?
Message 3 of 10
when I change the elevation code it moves to somewhere else. Thanks
Message 4 of 10
I'm not following you as well, but I'm wondering if this might be related to, and corrected by the "Elevation Origin" setting (e.g. Project Base Point, Survey Point, Relative).
Message 5 of 10
What is the host of the spot elevation?  A landing, a floor?
Message 6 of 10
It is a floor.
Message 7 of 10
I don't know why and I can't replicate the same behavior.  So my only suggestion is to change the elevation of elements from Properties, not from Spot elevations.
Message 8 of 10
@ToanDN: what are you trying to replicate? I don't understand the issue.
Message 9 of 10
Me neither. So I tried to do what she did and the spot elevation remained in place on plan.
Message 10 of 10
Sometimes it remains at its location, but sometimes it shows up somewhere else, probably it's just a bug.
