FLAT ROOF EDGE DETAIL
dm0144
dm0144
Hello everyone
Any idea/suggestion on how to model the raised edge, where the wall meets the roof, just like in the image bellow?
Accepted solutions (3)
Replies (15)
Alfredo_Medina
Usually, one wall type up to the roof level, and another wall type for the parapet wall. That second wall type might have other layers of materials and a profile family added as a sweep at the top, to create the coping.
Open and inspect the "rac_advanced_sample_project.rvt" that is included in the stock Revit Content - in the  "Samples" Folder.
dm0144
dm0144
@Alfredo_Medina @barthbradley
I have several questions regarding the join between the wall, roof and parapet wall.
1. How can I make only the concrete layer of the roof/floor to connect with the concrete layer of the wall? Something similar to having shape handles for the different layers of the floor.
2. How can I add insulation on top wrap on top of the parapet wall so the insulation is continuous from the facade to the roof?
3. How can I access the cap family, which I copied from the sample project, so I can edit it according to my wall thickness?
dm0144
@barthbradley
Is there a way to wrap the wall at the top (sketch bellow)?
Also, I applied the same functions for the same layers, and the finish layer of the floor didn't connect with the finish layer of the parapet wall.
RDAOU
@dm0144
Place the Finish layer outside the Core
dm0144
@RDAOU is there a way to wrap the insulation and finish layer around the core in section (close the top of the wall like in the sketch)?
We normally model the top wrap with a Floor or Roof and then use Join Geometry to remove the visible linework between the Wall's finish layer and this Floor/Roof.
Another approach would be to build it into the Wall Assembly using a Sweep/Profile.
...the method that is used for the Cap in this Wall Type:
JasonLLINDNER
Hey @dm0144 We do what @barthbradley mentioned and it is a nightmare I have to go through every time I have to work on soffits and parapets! Clad it with a roof or floor.
They should add the option to wrap all ends including top and bottom.
There's not too many alternatives. You could Paint the top of the Wall too.  It's not quantifiable "geometry", but neither is a Wall Wrap.
RDAOU
@JasonLLINDNER
There isn't really a need for a new feature. It is possible to wrap all wall ends. I didn't think there was a need to reply to this one since the OP was enlightened by @barthbradley 😉 right BB?
JasonLLINDNER
@barthbradley sometimes we do quantify them when the code applies but in general it doesn"t need to be quantified the possibility to have a wrap at the end similar to the option in the wall at end and insert would suffice to rid us of the nightmare of cladding top and bottom
JasonLLINDNER
@RDAOU I see. I always open to being enlightened with new ideas please do tell. I will post the question new not to hijack this one
RDAOU
You don't really need to...it has been solved previously on this forum and can simply search using the right keywords ... Solved: Layer wrapping at the bottom of the wall - Autodesk Community - Revit Products
apply the same principle at the top end
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
