First floor roof disappears when I go to floors above
fortywebs
fortywebs
Hi, when I look at the second floor plan I want to see the first floor extension roof, but it disappears, presumably because its eaves are lower than the second floor. How do I make it show? Oddly, it does show the gutter though. Thanks
Did you adjust your view range?  It needs to be set so that the roof below can be seen.
ennujozlagam
you can create a plan region in that portion and adjust the view range until you see the roof and hide the plan region in that view. thanks
