- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone. Hoping to get some help solving this mystery I'm having...
I am trying to copy this effect to show fire rated walls from a project. I made a YouTube video to demonstrate the issue here:
I am using a cut wall pattern graphic override to show a specific fill pattern based on a wall instance parameter. As you can see in the original project the graphic show fairly well at different zoom levels but in my project its just not showing up right and I did try to print it to PDF and it is just showing no pattern. Does anyone have any suggestions to get this working? Or if you have a better way to do fire rated wall patterns - I'm all ears...
Thanks for your consideration.
Link copied
