Fire Rating for Walls
4 REPLIES 4
sbaadkar
741 Views, 4 Replies
Revit needs to overlay a hatch pattern (.PAT) within the wall structure to address the fire rating issue.  Architects need to show fire rating for plan check.
Labels (2)
4 REPLIES 4
lucdoucet_msdl
in reply to: sbaadkar
@sbaadkar
As there is no standard architectural convention on the way to verify the fire rating and continuity of the walls bounding a space requiring a specific rating, I am curious to know why Autodesk should address in regards to your particular workflow.
I would propose that several workflows exist for internal verification and for documentation on plans of fire ratings for walls that use or do not use a fill pattern are available.
Could you elaborate on why a fill pattern is required in your case?
-luc
Coarse scale fill pattern doesn't work for you?
syman2000
This is old blog but it still works
https://bim4scottc.blogspot.com/2011/09/using-filters-to-show-fire-ratings.html
in reply to: syman2000
That doesn't work well for patterns.  That's why they show solid colors in the tutorial.
