Filter Patterns Changing in Fine Detail Level
motismatt
motismatt
I've applied a filter to walls to show fire ratings. However, the pattern is only showing up correctly when on coarse detail level. When switched to medium or fine, the pattern fills to solid black. Another thing that is strange is that the pattern will show up correctly on an existing wall on fine detail, but not on a new construction wall. Is there a way to make the pattern show correctly at fine detail on a new construction wall?
Phase settings are at "show previous + new" and new construction.
nicholas_seibert
Check your phase filter overrides, sounds like they could be changing the patterns of your walls.
If you set the filter to None in the view does everything work ok?
Nicholas Seibert
Principal Revit QA
RevitRx
is it a view filter applied in visibility graphics? or did you apply the filter in the wall properties?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
www.RevitRx.com
Can you tell us a little more about this filter you created?  How was it created, applied, etc.?
