Filter Patterns Change in Wall Pattern
kshiblyH22QX
kshiblyH22QX
I've applied a filter to walls to show fire ratings. However, when I change the detail level to Fine, the pattern turns solid.
Is there a way to make the pattern show correctly at fine detail for a wall?
Yes.  Duplicate the core material and assign a fire rated pattern for the cut pattern.
kshiblyH22QX
Thank you but I don't want fire rating pattern to show up everywhere. Only where I have the fill pattern filter set.
Any alternative solutions?
Yes.  Create parts > Override parts material to show the fire tape pattern > Set views that you want to show the fire tape to show parts.
Alfredo_Medina
The issue seems to be related to the scale of the view, not to the detail level. Maybe you can use 2 view filters, each with a different hatch pattern, and maybe add that to your view templates.
