Filter of Project Browser Organization Missing "Include" Operator
nozci
nozci
Filter of project browser organization has "Equal to" and "Not equal to" operators but it is missing "Include" operator.
If it had, it would have reduced the number schemes to be written. Is there a way to work around this?
RC_RVT
what are you trying to filter the browser by that it needs more than 3 filters? My workaround would be to create a shared parameter that you filter by in the browser organiser, and then add the correct details into that shared parameter on all the views you want to remain visible in your browser.
E.g. New shared parameter = Visible in Browser
Views you want visible = Visible in Brower: Yes
Views you don't want visible = Visible in Browser: No
Then filter your browser organisation by Visible in Browser is Equal to: Yes
Obviously this is just an example, but not sure if this is the sort of thing you would be thinking about?
nozci
I was filtering based on names, and it was one view at a time. Now using View Tag1, 2, 3 as text parameter and it is more flexible now. It is a good solution using parameters. Thanks.
