Filter for working-auxiliary Sections
Message 1 of 8
Hello. How do we set a filter so some auxiliary sections used only for working or draft are not seen in the published or printed plans?
Replies (7)
Message 2 of 8
Alfredo_Medina
  1. Create a type of section (duplicating an existing section type). Include the word "Working" in the name of the type.
  2. In the filter dialog box, create a new filter, such as "Ref. Symbols - Working" ; Categories = Sections ; Filter by = Family and Type ; contains = "Working".
  3. Add the filter to a view, and turn the filter off.
Message 3 of 8
chrisplyler
I'm a bit confused.
Since I never add my "working" Views to Sheets, they never get into the printed drawing sets anyway.
And you can't have one View inside another View, so I don't understand the idea of using a View Filter to filter out views from a view.
Message 4 of 8
Alfredo_Medina
The purpose of the filter is to hide any "Working" section from the view. The reference symbols that correspond to the working sections.
Message 5 of 8
chrisplyler
Ahhhhhh. I'll smack myself in the forehead now.
Message 6 of 8
Maybe he means the section/elevation tags on floor plans. If that is the case, so a View Filter would work. If those views are not placed on Sheet, then simply check Hide Unreferenced View Tag in plot settings.
Message 7 of 8
It worked with Filter by_View Name_Contains_Working.
Thanks!
Message 8 of 8
this breaks projects. this finds the same view family type elsewhere and hides other sections, elevation and callouts in the view.
You should work on a real project as you will find real practical concerns. Autodesk needs to think about adding a type filter for views and then this will work.
