I created filter for overriding elements color depending on parameter value. I use additional parameter to define material but I noticed, when condition is fulfilled, both hidden and visible part change to this color.
Wall on the left is defined throuh visibility graphics, wall of the right is changed through filter.
Is there possibility to differentiate color for hidden line, like it is is visibility graphics one?
Solved by barthbradley. Go to Solution.
Create a new Linework Line to use or Override Graphics in View By Element.
Ok, but this would require changing it manually in every view, right?. I thought there was a chance to do it automatically, like filters.
