Filled Regions not Filling
jacob
jacob
We have two nearly identical details. In fact, in the image, the detail on the right was drawn first, then the view duplicated and modified for the left detail. For some reason, none of the filled regions are filling on the left.
The plywood, gwb, and insulation should all have appropriate hatching like the right details. When new regions are created, they suffer from the same ailment, borderlines show, interior hatch does not.
All the visibility settings are the same
VG is set to show the detail items (all on)
Same Scale
Same Detail Level
Both in Hiddenline
Nothing is hidden on either drawing
Thank you.
- Create a new drafting view
- Select all detail components from the faulty view, copy and paste to the new Drafting view
What do you see?
jacob
I duplicated the drafting view and the regions worked like normal.
Which is great and all for a workaround, but I am curious if we can fix the issue in the drawing.
If this is the case then I think someone must have selected all the detail components in that view and override their pattern to invisible.
jacob
Unfortunately, they are not overridden.
This might just be filed under "things with no real reason"
Yes I was regretting my reply but it was too late. You already mentioned drawing new filled regions showed no patterns, so it was not the override issue. It maybe just that the view is corrupted. At least the fix is easy enough for you.
