Filled Region
4 REPLIES 4
213 Views, 4 Replies
Filled Region
How do I make a filled region transparent? I want to see what is behind the hatch pattern Thanks Doug
Filled Region
4 REPLIES 4
Can't be done currently. It has been requested in the past but it wouldn't hurt to add you name to the list. Here is a workaround: http://www.zoogdesign.com/forums/phpBB2/viewtopic.php?t=755 Z. Doug wrote: > How do I make a filled region transparent? > I want to see what is behind the hatch pattern > > Thanks > > Doug > >
I just saw that transparent filled regions can now be done in 6.1. Doug wrote: > How do I make a filled region transparent? > I want to see what is behind the hatch pattern > > Thanks > > Doug > >
Further to this thread -
I am using R7, I have my filled region as transparent but it will still not show what is underneath. I have even tried the send to back options. It does not seem to do anything
any clues?
any clues?
What pattern do you assign to your region? If it is solid white you won't see anything. Change it to something else
