Filled region with line pattern in background/underlay
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey!
I was hoping to get some help with Fill patterns that doesn't behave the way I would like it to. I don't know if it is an issue in Revit or if it's not just possible.
The way I want to present fill pattern is exactly as Revit sees the pattern; with the fill pattern in the background and model elements in the foreground. Although, when I print to PDF, the lines from the pattern always gets promoted, or "Send to Front". This does not occur for Solid fills, which is strange. If I have a pattern with a Solid fill AND a diagonal fill, the solid fill is in the background and the diagonal fill is in the foreground in the PDF. Is there any solution for this? I use Revit 2020.2, and when I export I use Bluebeam with Line Merge (Multiply)
This is what Revit sees:
And this is what the PDF sees:
The diagonal pattern is in Foreground, I have tried changing it to background but the outcome is the same. The lines from the Filled region always gets prioritized.
If I don't use the Bluebeam PDF exporter, the lines from the Filled region goes over everything.
Regards
