Filled region draw order/masking in nested family
laura.BM
laura.BM
I have a crane family that contains a nested family with Filled Regions for the plan depiction. My problem is that the appearance gets messed up when I load the family into a test project. I'm not sure whether it is a problem with the draw order or the masking effect of the different filled regions.
First image: Desired appearance in family editor
Second image: Messed up appearance in project
If I load the 2D-family directly into the project (not nested within crane family) it works as intended:
Could this be something to do with the parameters in the family constraining the fills?
Maybe what you need is a Masking Region?  MRs can be drawn on/hosted to named Ref. Planes/Work Planes if "Draw in Foreground" is unchecked.   Read this AKN Article to learn more:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
laura.BM
Hi, thanks for the answer!
I didn't go with masking regions on purpose, since I want to be able to change the colour, but unchecking "Draw in Foreground" box solves my problem.
duncan.lithgow
This should be very embarising for Autodesk. I have also not found a solution. It a very old problem, here's a more recent post from 2014 https://revitforum.org/showthread.php/20286-Filled-regions-in-detail-component-masked-by-model-eleme...
