Fill pattern Hatch issue
wr.marshall
Advisor Advisor
Message 1 of 8
wr.marshall
I am placing a window into a wall, but the moment I do it messes up the hatching on the wall. it also messes up a connection on a perpendicular wall. Please see below screen shots showing with and without a window. Please advise any solution or reasons why this is happening
Wall Hatch Error 1.pngWall Hatch Error 2.pngWall Hatch Error 3.pngWall Hatch Error 4.png
Replies (7)
Message 2 of 8
Where is the fill pattern coming from? Is it coming from a Material? Is it coming from the Wall Type's Coarse Fill Pattern?
Message 3 of 8
wr.marshall
Not sure where it is coming from. Just noticed something obscure in the window family when create a legend plan, which I cannot see in the family. attached family for review. Suspect what ever the rectangular shape is the thing causing the issue.
Message 4 of 8
Turn off the Wall Category in Legend View?  That make it go away?
Message 5 of 8
...regarding the wall hatching issue: I just test your family and I can't seem to replicate.  You say that when you place this family in a Project Wall, it affects the Wall Hatch Pattern. No issues in my testing. I tested with both the Wall's Material Cut Fill Pattern and Coarse Fill Pattern.
I did see one problem related to the Flip Control, but I corrected problem by deleting original Flip Control and replacing it with a Double Vertical and a Double Horizontal, and making the Center (Left/Right) Ref. Plane an "Origin".  FWIW.
Message 6 of 8
syman2000
Did you try set the hatch pattern to align with element?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Message 7 of 8
elzohry2007
it's alwase happen
hatch in revit have some difficultes
the best way to use hatch with alot of lines
Message 8 of 8
wr.marshall
The issues with flip controls is that non symmetrical components like a window that only opens one side sets it as the same type whether the opening is on the left or the right. Even though these 2 windows have the exact same dimensions the mere fact that one opens left and the other opens right makes them 2 different types when creating schedules .
