Hello. It's my first time using Revit so I'm a complete beginner so apologies in advance if this is a silly question. I'm following YouTube tutorials but this issue doesn't seem to be in line with any of the videos I'm watching.
I'm trying to build stairs by sketch since one wall is diagonal. I'm following the tutorials with the boundary line, drawing in the risers etc, but it always says "1 riser created" no matter how many I draw in. When I look at it in 3D view, it's completely flat, and when I tick to complete I get the error "Invalid sketch, can't create run by this sketch". The properties panel on the left seems to suggest the riser should be 192.5mm, and I'm drawing them at 1000mm spaces (it's for cinema seating), so I can't fathom what I'm doing wrong. There is also no option in the left panel to go from level 0 to level 1 - most things seem greyed out.
I've attached the drawing, you'll see some of the higher steps will end up being above level 1 rooms, but it should work height-wise as those rooms won't take up the whole height.
Could anyone please help?? I'm spending hours on this and getting nowhere! Thank you
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
System defined stair limits each riser height , width and depth . You can change it make it a new stair type. Then you are free to go.
Thanks for your response. It's as if that works fine when I just use Stairs (see 'Cinema Stairs' attachment) but as soon as I click 'Create Sketch', it somehow forces it back to a different type of stair and the left panel is almost entirely greyed out ('Cinema Stairs 2' attachment). Stair by run works completely fine except it won't fit properly into an odd shaped room. Sorry if I'm missing something completely obvious.
By the look of it, you have one too many boundary lines (green) and no Stair Path. Replace the Boundary Line at end of the run with a Riser Line (blue) and then place a Stair Path from first to last Riser.
I can't believe that's all it was! I was drawing the boundary all the way around, not just the edges of the stair. Thank you so so much.
