File won't open in a different PC, Revit becomes unresponsive.
rinobonalos24
Message 1 of 13
rinobonalos24
Hello, I have a Revit 2024 file that I made on my laptop previously (last saved about a month ago), but for some reason I needed to have my laptop fixed so I borrowed a friend's laptop to continue doing some work.
I copied my saved files to an external hard drive and proceeded to open Revit 2024 on my friend's laptop, but every time I try to open my file, it shows up a blank page on the software, that would later on become unresponsive. I've tried uninstalling and reinstalling Revit, making sure no links are included in the Revit file. I've checked it on my laptop and it opened my file normally, but on my friend's laptop it won't.
Here are some specs if you need them:
My Laptop:
- GTX 1660ti
- 8GB Ram
- Intel Core i7-9750H @ 2.60 GHz
My friend's laptop (the one who can't open my file for some reason):
RTX 3060
- AMD Ryzen 9 5900HX with Radeon Graphics 3.30 GHz
- 16GB Ram
I've also attached the file and some screenshots if it helps. Thank you!
Replies (12)
Message 2 of 13
Simon_Weel
File opens fine on my side. Can you open a new project on that notebook?
Message 3 of 13
rinobonalos24
Thanks for trying it out. Yeah I can create a new project. I've also installed the Revit Libraries on my friend's laptop too but it still becomes unresponsive.
Message 4 of 13
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-does-not-lau...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Freezing-Not-Respo...
Message 5 of 13
ridantuo
And how long have you waited approximately?
30 seconds, 5 minutes, 15 minutes, 30 minutes, 2 hours?
I'd first try ennujozlagam suggestions.
Sounds a bit like it is trying to find a path or paths to some files and is having trouble with them (material, templates, Autodesk system data). Some paths/data might be structured slightly differently or access to something might be denied? Run as admin is a good thing to try also. At some cases, running the Autodesk Access (formerly Autodesk Desktop App) before Revit (on the first run for instance) has fixed these kinds of things.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Message 6 of 13
austintolentino14
Observer
Observer
Hi have you fixed this problem already im having the same issue
Message 7 of 13
nozci
Is the version 2024.3 ?
Message 8 of 13
austintolentino14
Observer
Observer
Its 2024.2
Ive been using this file to my desktop which is also 2024.2 then at home ive been using it to my nitro 5 which is also 2024.2 and then i bought a new laptop zephyrus g14 it wont open. Especially files that is 200mb and higher. I really dont know the problem
Message 9 of 13
nozci
2024.2 and 2024.3 have some file opening problems. 2024.3 has more.
Message 10 of 13
austintolentino14
Observer
Observer
So there is no solution on this?
Message 11 of 13
nozci
If it was 2024.3 I would say no. For 2024.2, I am not sure. Wait for the other users to answer in the forum.
Message 12 of 13
austintolentino14
Observer
Observer
Hi i do have the same issue and i tried to open your file with my laptop i encountered the same issue but when i opened it to my desktop it works fine. Both of my desktop and my laptop have the same specs
Message 13 of 13
danielxg
Observer
Observer
Anyone can solve this? I have the same problem and I didn/t find the solution yet. I tried to open your file and I couldnt.
