File Size _ What causes a file to increase it's size
I've created Revit Project Files with the Architectural Template: LT_USI_Default File,
which is approximately 3,120 KB's.
When I Transfer Project Standards and bring in selected types and things like our company title sheets ,
the file jumps up to 412,668 KB's in size.
What would cause a file to increase it's size so large ?.....and  What can I do to decrease the file size ??
L.Maas
Project file size is an accumulation of all the things. things that might impact the size
-Quantity of families
-Many highly detailed families (large sized families).
-Import of foreign file formats (e.g autocad dwg's).
-Import of large images (e.g logo's)
-No consistency between families causing build up of materials, line styles etc.
Especially if you done a lot of work in your families/projects it can help to do a "Save As" and select "Compact File" under the options.
Louis
Please mention Revit version, especially when uploading Revit files.
Embedded DWG's will add quite a bit of weight too...
So if you have DWG details in drafting views that will cause a huge increase.
