File Save Options Setting a default
In revit 2013
How do I control the Control File Save Options Settings globally.  For example I want all files to save only one back-up file.
constantin.stroescu
from Aplication Menu (big R) >Save As >Project > Options > File Save Options > Maximum backups ....change the number to 1..Image 370.png
Constantin Stroescu
Thanks is there a way to set this as a default for all new projects?
constantin.stroescu
yes ,
open the template file and make the setiings for number of backups in Save as....
If you use a Revit Template it is possible that the template file to be write protected , so make your own copy of the file...
When making a new file , use this template...
Constantin Stroescu
GHASEM_ARIYANI
Hi
If repeated, it is hard to save the project Or you might forget.
I would recommend this to change in the template to apply to become permanent.
The following procedure:
1-Open the default template.
2- Click Application > Save As > Template.
3-Now, Specify Save In Custome Template and Specify  File Name For Template And then Click Options and Set Maximum backups to 1.
4-Now,Close your file and Go to Application > Options > File Locations > Project Template and Add Custome Template then click the Ok.
5- After this, The page recently Click on the template and the project start
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
